Datsun 240z, 260z, 280z , and 280zx Parts
240z parts:
INTERIOR:
73 choke cables w/ **** $25.00
70-73 arm rests (2 pairs available) $20.00 pair 1 PAIR SOLD
70-73 door straps (4 available), no chrome trim $5.00 each 1 PAIR SOLD
70-73 Black Visors $20.00 pair
70-71 Auto Trans Shifter Plate, one corner gap filled in with epoxy paste and painted $20.00
71 240z complete brake box w/ spring loaded pedal and pedal bumper $20.00
71 240z w/factory AC used dash harness, 1 or 2 damaged wires, the rest is in good shape $35.00
70-73 interior taillight finisher 2 repairs but clean $25.00
72-73 turn signal switch, 1 repaired wire $30.00
EXTERIOR BODY
72 drivers' side metal headlight bucket, some bondo on side, all studs intact; $20.00
73 front bumper mounts painted with SEM Rust Shield $25.00 pair
70 “Datsun” metal fender badges repainted and clearcoated $50.00/ pair SOLD
70 “Datsun” metal round hood badge repainted and clearcoated $33.00 each SOLD
70 “240z” metal c-pillar emblems repainted and clearcoated $55 for 3
70-72 front bumper, trim complete with bumper bar, interior painted with SEM rust shield. All mounting points intact, very good shape. $200.00 SOLD
70-72 front bumper mounting brackets painted flat black $25.00/ pair SOLD
EXTERIOR ENGINE BAY
72-73 Heat Shield; the one with the "U" cutout $25.00
260z 280z parts:
INTERIOR:
77 280z brown visors $20.00
77 280z Ebrake assembly w/ boot $20.00
77 280z Speedo cable $20.00
77-78 280z headlight combo switch ( 2 available) $25.00
74-76 260Z 280Z headlight combo switch $30.00
77-78 280z turn signal switch (2 available) $25.00 1 SOLD
75-78 280z ignition relay tested and working $20.00
75-78 280z 160w heater AC blower motor (3 available) $20.00
75-78 280z heater fanblade "cage" assembly ( 2 available) $20.00
77-78 260z 280z oil pressure/ water temp gauge $20.00
77-78 280z gas gauge/ voltmeter (4 available) $20.00
74-76 260z, early 280z gas gauge / voltmeter $20.00
75-78 280z heater casing w / 1 vacuum pot & sensor $20.00
77-78 280z horn pad w/spring and plastic screw receptacles $20.00
75-78 Drivers’ side Black interior rear ¼ panel $25.00
EXTERIOR BODY:
75-78 280z Front Valance, "end buckets" (2x2 each) great shape $25.00 each
77-78 Driver & Passenger side headlight bucket, all studs intact. No dents or bondo. $25.00 each
74-78 Rear License Plate Light Frame, used but very nice, harness intact $25.00
74-78 Taillight gaskets; used in good shape $10.00/ pair
75-78 Hood Cowl Piece, Underneath treated w/ SEM Rust Shield (2 available)$60.00
77-78 Front Bumper Overrider w/ bumper mount covers trim piece $25.00
EXTERIOR ENGINE:
77-78 280z stock fuel pressure regulator (2 available)$20.00
75-78 280z thermostat housing, complete w/ switches, not sure if they work, $25.00
75-78 280z relay bracket; comes with fusible link holders ( one is missing), a collection of fusible links, voltage regulator & water temp. relay $20.00
75-78 280z Air Cleaner to AFM boot $10.00
75-76 280z AFM to throttle body boot, no side outlet $10.00
75-78 280z throttle body w/TPS and BCCD intact $20.00
75-78 280z transmission shifter boot hold down bracket $10.00
UNIVERSAL S-30 ZCAR:
70-78 Very Clean Window Crank handles w/clips and plastic washers $25.00 / pair SOLD
70-78 Rear Hatch Latch $10.00
1970-1978 240z-280z windshield trim sets complete, in good shape, no dings, rust or deep scratches $30.00 + $27.00 shipping
70-78 Shaved and polished thermostat cover $20.00
70-76 pair of threshold plates, cleaned and painted w/ aluminum engine enamel $20.00/ pair
1970-1978 240z-280z rear hatch trim sets complete, in good shape, no dings, rust or deep scratches $25.00 + $20.00 shipping
70-78 Hood inspection Lids Driver & Passenger $20.00 / pair
1970-1978 s-30 ZCAR strut tower round caps $10.00/ pair
70-76 driver & passenger door mechanisms (3X3 available) $20.00 each
74-76 260z-280z door window frames $20.00/ pair
70-76 door dovetails, painted w/ chrome paint $20.00/ pair SOLD
74-76 passenger window regulator $25.00
70-83 stripped and polished “TURBO” valve cover $105.00
70-78 dash fan vent chrome plastic ball swivel ends, very good shape $25.00/ pair
280zx parts:
1979-1983 stock fuel pressure regulator (2 available) $20.00 each
1979-83 Rear hatch stoppers and rubber bumpers $20.00/ set
1979-83 Green Lighter (6 available) $10.00
79-81 center gauge pod with all gauges except clock (2 available) $20.00
79-83 80 mph speedo cluster , maroon surround $25.00
79- 83 b-pillar to b-pillar interior roof trim black $25.00
79-83 b-pillar to b-pillar interior roof trim maroon $25.00
81-83 turbo hood vents, one missing stud between them $30.00
79-83 AFM #A31-622-420 #929 removed from running vehicle $35.00
79-83 Coupe Gray door threshold plates left and right $30.00/ pair
79-83 Coupe Black Seat Mechanism covers left and right $30.00/ pair
79-83 Coupe Gray Kick Plates left and right $30.00/ pair
79-83 Under Dash Plastic Trim Plates left and right , black $35.00/ pair
1979 B-Pillar Coupe Stainless trim/ pair $20.00
79-83 Black Seat Mechanism Covers $25.00/ pair
1979 Hood Plastic cowl piece $20.00
1979-83 T-Top Surrounds $20.00/ pair
79-83 Maroon swivel dome lamp $20.00
79-83 Black swivel dome Lamp $20.00
79-83 Interior fan vent piece; good chrome surround $20.00
79-83 Lock Pillar Trim pieces 2 driver 1 passenger, hole ends on one pair have been repaired. $20.00 for repaired ones, $30.00 for good one.
79-83 wheel caps for 6-spoke 280zx wheels, okay to good condition $25.00/ set
79-83 A-Pillar Trim Black ; one area of invisible repair on drivers' side $30.00/ pair
79-83 Coupe Manual Console Black w/ Boot, mirror toggle switches, i.d. plate & LED. $75.00 SOLD
79-83 Coupe Black 1/4 window trim w/ doglegs great shape $50.00 each side $90.00/pair SOLD
70-83 keyed ignition switch , great spring, lock and conductivity $60.00
NOS 280z (may be able to be retrofitted)
Sway Bar End Links 54618-u1000 list; $21.18 each sell; $25.00/ all four
Control Arm Bushings 54535-e4100 list; $9.00 each sell; $14.00/ pair
75-76 280z efi relay NOS $55.00
OE and AFTERMARKET 280Z PARTS (may be able to be retrofitted)
77-78 OE Rear Wheel Brake Cylinder 44100-n4601 list;$ 81.65 each sell; $100.00/ pair
78 OE Brake Master Cylinder 46016-n4301 list; $ 283.87 sell; $125.00 SOLD
70-78 Rear Strut Bearings Enclosed Style NEW $12.00/ pair
Pictures available for everything. My email address is dhp123166@yahoo.com
Shipping will be extra charge. Local pickup available. Delivery available in SoCal for a small fee.
All items are ready to be shipped.
All shipments are tracked from my end, please let me know if there is an issue.
Turnaround from purchase to shipment is less than 24 hours.
Shipping will be from 93004.
I only accept Paypal or cash.
Add 3% Paypal fee to final value of transaction.
Thank you for your interest.
INTERIOR:
EXTERIOR BODY
EXTERIOR ENGINE BAY
260z 280z parts:
INTERIOR:
EXTERIOR BODY:
EXTERIOR ENGINE:
280zx parts:
dhp123166
28
04-10-2012 10:58 AM
dhp123166
06-18-2010 08:45 AM
yves280zx
12-16-2006 01:39 AM
