Help with my 78' 280Z engine Please
Old 02-18-2012 | 01:09 AM
3d_Ryan's Avatar
So I went out to start up my Z. When i turned it over i heard a spraying noise and it smelt like gas! I popped open the hood and gas was spraying out of the pipe that goes back and forth near the valve cover. I circled it here and put an arrow near where it was spraying.
Main question is: What is this? Whats the part i need to get to fix this? and How?
Thank you!
-3d_Ryan
30165760025_large.jpg?t=1329551890
Old 02-18-2012 | 10:27 AM
Welcome to ZDriver!
It's called the "fuel rail" and it delivers the fuel (gasoline) to the fuel injectors.
The fix depends on what's wrong... it's most likely a loose clamp.
Make sure you buy a Haynes manual or download the FSM (factory service manual) for free at www.xenons30.com/reference
Old 02-18-2012 | 11:38 AM
zenzee's Avatar
Leaking fuel
Thank you!
-3d_Ryan
Nismo is correct, however you can also have an injector hose sprung a hole or leaking where hose seals to injector body. I also noticed an old style injector fuel feed hard lines with lots of hose connectors which can cause lots of problems and one such as starting a fire. Try getting a late 78 Z OR 79 and later fuel feed line that has no hose connectors on top of it. Then you'll have a safer more efficient fuel feed line. That is one of the best upgrades on an early z intake manifold. Do it soon and save the Z. Good luck.
Old 02-18-2012 | 10:05 PM
3d_Ryan's Avatar
Welcome to ZDriver!
OKAY! thank you so much! I'll be at a Z yard to see if i can find it! thank you!
jwhite927458
05-22-2014 01:58 PM
Frankenstein
08-26-2012 12:46 AM
VixisX
01-12-2012 07:23 PM
rjc280z
05-27-2011 11:48 PM
Superduner
06-06-2006 08:33 AM
