Polished stainless Turbo downpipe
For sale here is a 2.5" mandrel bent ****Polished**** Stainless Steel Turbo Downpipe for your Turbocharged 240Z 260Z 280Z. This downpipe has the hard to find Nissan T3- Flange on it so you can run it off the stock turbo. The flange is Stainless and the pipe has the O2 bung welded in. If you are running the stock DP this flows sooo much better. I ran the stock downpipe for a while and then switched to a DP almost exactly like this and noticed a huge difference, Plus you dont have to worry about it rusting!!! This will fit thoes using the Nissan transmission, Im not sure if it will fit if you are using the T5 tranny without modifications. This is up on ebay so please stop by and check it out.
http://cgi.ebay.com/ebaymotors/ws/eB...m=270217238356
thunderz
02-12-2006 07:46 PM
