FS: 1987 300zx non turbo
Old 05-15-2013 | 08:20 PM
MMiskoe's Avatar
1987 Nissan 300zx built for SCCA ITS
This means it has a pretty tweaked suspension, blue printed an balanced motor, full race exhaust (see pics), mostly gutted interior, still retains glass, dash, lights. It is a competative car in its class which includes 2nd gen RX7's, Datsun 240Z, E30 BMW 325, Porsche 944 among others. You can take this car to go road racing from coast to coast and find the same rule package in place. If you ever wanted to go road racing, this is a great class to do it in and this car would suit you well. It is time for it to move on as I have moved on to other projects.
See it here, skip ahead to about 7 minutes where it is the car directly ahead of camera car:
NASCAR door bars on both sides
RH side net
19 row oil cooler w/ remote filter & t-stat
Oversized radiator – (never worry about over heating)
NISMO clutch LSD differential
Fire system
New motor in 2009
New clutch last season
Nis-Tune programmable ECU
Mechanical oil pressure, oil temp & water temp gauges
Fully adjustable rear suspension (camber & toe)
Urethane suspension bushings
Camber plates in front, coil overs at all 4 corners
16 identical 6 ½ x 15 wheels
All records & notes available
Extensive collection of spares
Annual tech was current through September of 2011, car will need new harnesses to pass now.
This is a very reliable car, 4 mechanical DNF’s in its entire life (25 races +/-). Needs gas & set the tire pressures, otherwise is ready to go racing, leave it on the trailer between events if you like.
The 2010 season has yielded three Second places and four Third places out of seven races. $5000
Located in New Hampshire, can deliver w/in greater New England Area.
MMiskoe57 at Comcast.net
603-228-0257
42 300zx ITS Photos by MMiskoe | Photobucket
bholm210
FS: 300ZX (84-89)
18
04-05-2015 10:28 PM
Genuts
FS: 300ZX (84-89)
02-05-2014 09:08 AM
turtle10433
09-22-2011 05:44 PM
Mikey21
FS: 300ZX (84-89)
08-05-2010 05:44 PM
turboz31
FS: 300ZX (84-89)
07-02-2006 01:20 AM
