Lot's of performance/stock parts ... selling all .. VG30DET
Old 12-18-2005 | 12:57 PM
jjm300zx's Avatar
I have a web page http://www.geocities.com/jjm240z/ that I'll keep updated as to what's sold already. Please check it before emailing me about a part. Thank you.
Here's a run down of what I have:
-VG30DET from a cima/cedric. The oil pan has been swaped to one that clears the crossmember, the dipstick is switched to the correct side, and the motormounts are modified to bolt up to the z31. See the pics of the engine in my 88t. This is a turbo version, so the turbo manifold for the VG30DET is included. $800 + shipping
-Z32 turbo transmission. I was planing on using this with the VG30DET. $450 + shipping
-New McLeod 6-puck clutch for the Z32 tranny. See details $775 new. $600 + shipping
-Lightweight 8-bolt aluminum flywheel (8-bolt for the VG30DET) $450 new, $300 + shipping
-88t z31 transmission. $450 + shipping
-competition engineering fuel tank sump. $60 new, $40 + shipping
-miscelaneous braided steel fuel lines, solinoids, etc...
-custom built water to air intercooler (see pics of it installed on my 88t with the vg30et) includes pump, silicon couplings, t-bar clamps, HKS Blow off valve, etc... $400 + shipping
-New SPEC sprung hub 4-puck clutch (part #sn423 stage 3 $365 new rated for 465 lb/ft)for the 88t z31. $370 new, $290 + shipping
assorted mandrel bends... some nice 3" S.S. mandrel bends, misc other bends. $30 + shipping
-Mallory window rpm switch. $125 new, $50 + shipping
-Performance Electronics ECU, used ~5000 miles with my vg30et. includes all the sensors from when I had it working with on my 88t including a 2-bar map sensor and air temp sensors. $900 new, $650 + shipping
-white 88t z31 missing the vg30et engine. Body's in good shape. Alloy stock wheels, brown leather int. t-tops good. Rockford Fosgate speakers installed. Email me with what you're looking for.
-Bilstein shocks ($450 new) with low miles on them (not sure of exact mileage, but I only put less than 10,000 miles on the car the entire time I had it. $290 for the shocks, + shipping
-New Addco urethane endlink bushings and Prothane urethane control arm bushings. $25 + shipping
-so many misc z31 parts, mostly from the 88t ... upper and lower manifolds, MAF, etc..
-New 17x9 5-spoke aftermarket cobra wheels with black finish. 5x4.5 bolt pattern, 23mm offset ... set of 4. Paid $450, $370 + shipping
-Two Epsilon 3 piece wheels. Very rare, very light (~8 kg). These are three piece modular wheels, which means you can swap the rim around to adjust backspacing from ~2.5" to ~6". size is 17" x 9" $200 + shipping
-New Walbro z32 in-tank fuel pump. $90 + shipping
-88t T25 turbo. normal shaft play. I believe the seals were leaking. $30 + shipping
-88t rear control arm, rotor, and caliper as an assembly to retrofit the 87-89 rear vented brakes to 84-86.
-88t front hubs, rotors, and calipers to bolt right on to any 84-86 strut for the better dual piston calipers with slip-on vented rotors Make an offer
-Interior parts. most of the interior is in good shape. The drivers seat has one busted seam. Beyond that, email me with what you're looking for.
I know I'm missing some stuff. I have to liquidate this stuff immediately. I can ship or you can pick up the parts. I am located 10 minutes outside of Hartford CT.
Pictures are posted at http://pg.photos.yahoo.com/ph/jjm240z/album?.dir=/32b1
I can be contacted via email at jjm240z@yahoo.com
My phone number is 860-250-6145. Please call only with serious inquiries. I think the listed prices are fair.
Old 12-19-2005 | 11:01 PM
jmmorriso's Avatar
Im looking for complete z31 front struts.
zwhore
07-30-2012 01:31 PM
tay-fu300zxtt
FS: 300ZX (90-96)
01-15-2007 07:36 PM
stcrispin
06-24-2005 01:21 PM
