Parting out '86 Base NA - Laguna Niguel, CA
Old 09-07-2010 | 12:48 PM
xxVERITASxx's Avatar
EMAIL: blakelatin@gmail.com
PAYMENT PREFERENCE: Pay Pal or money order
SHIPPING: Parts on request at buyer's expense or Pickup
Price: Make an offer!
1986 Nissan 300zx Base NA
AC Compressor $140.00
AC Condenser $80.00
Alternator - New/Reman $65.00
Auxillary Air Valve $40.00
Blower Motor $30.00
California Legal Catalytic Conv. - New/Reman $125.00
Crankshaft Position Sensor $80.00
Distributor (with cap & rotor) $100.00
Distributor Cap - New $10.00
ECU $120.00
EGR Valve $50.00
Fan Clutch $20.00
Floor mat - Black $20.00
Fuel Cap $5.00
Fuel Injector (with connector) $20.00
Fuel Pressure Regulator $30.00
Fuel Pump $120.00
Fuel Tank $100.00
Heater Core $40.00
Idle Air Control Valve $60.00
Idler Pulley - New/Reman $15.00
Igition Control Module $65.00
Ignition Coil $15.00
Ignition Coil - New/Reman $20.00
Ignition Switch $25.00
Knock (Detonation) Sensor $120.00
LH Camshaft $80.00
LH Camshaft Pully / Timing Gear $20.00
LH Exhaust Rocker Arm Shaft + Arms $50.00
LH Intake Rocker Arm Shaft + Arms $50.00
LH Window Reg/Motor $50.00
MAFS $90.00
Motor Mount $40.00
Muffler $20.00
O2 Sensor $20.00
Oil Pressure Switch $15.00
Oil Pump $60.00
Power Steer Pump $50.00
Rack & Pinion $60.00
Radiator $75.00
Rocker Arms $15.00
RH Camshaft $80.00
RH Camshaft Pully / Timing Gear $20.00
RH Exhaust Rocker Arm Shaft + Arms $50.00
RH Intake Rocker Arm Shaft + Arms $50.00
RH Window Reg/Motor $50.00
Starter - New/Reman $60.00
T Tops $200.00
Tires - 90% Tread left $160.00
Throttle Position Sensor $25.00
Water Pump $15.00
Basically anything you can think of... just let me know! Will send pics on request.
Old 09-07-2010 | 01:26 PM
Moved to that place we call "CLASSIFIEDS".
Old 09-07-2010 | 01:29 PM
Thanks!
Old 09-09-2010 | 06:59 PM
CLICK HERE FOR PICTURES!
Old 09-12-2010 | 10:17 PM
Updated Availability and Pricing!
AC Compressor $105.00
AC Condenser $65.00
Alternator - New/Reman $50.00
Distributor (with cap & rotor) $80.00
ECU $80.00
EGR Valve $40.00
Floor mat - Black $16.00
Fuel Cap $5.00
Fuel Injector (with connector) $16.00
Fuel Pressure Regulator $25.00
Idle Air Control Valve $50.00
Idler Pulley - New/Reman $12.00
Igition Control Module $50.00
Ignition Coil $12.00
Ignition Coil - New/Reman $16.00
LH Camshaft $65.00
LH Camshaft Pully / Timing Gear $16.00
LH Exhaust Rocker Arm Shaft + Arms $40.00
LH Intake Rocker Arm Shaft + Arms $40.00
LH Window Reg/Motor $40.00
Mass Air Flow Sensor $75.00
Power Steer Pump $40.00
Radiator $60.00
RH Camshaft Pully / Timing Gear $16.00
RH Exhaust Rocker Arm Shaft + Arms $40.00
RH Intake Rocker Arm Shaft + Arms $40.00
RH Window Reg/Motor $40.00
Side Panel Right $75.00
Side Panel Left $60.00
Rear Carpet $50.00
Door handles $20.00
T Top Left $125.00
T Top Right $125.00
Seat Passenger $40.00
Seat Driver $40.00
Headlight Right $25.00
Headlight Left $25.00
Old 09-30-2010 | 09:38 AM
Updated Parts & Prices (Note: Buyer to pay shipping):
AC Compressor $80.00
AC Condenser $40.00
Alternator - New/Reman $60.00
California Compliant Catalytic Converter $120.00
Camshaft Pully / Timing Gears (Set) $30.00
Distributor (with cap & rotor) $95.00
Door handles $20.00
Door Panel Left $65.00
Door Panel Right $75.00
ECU $24.00
EGR Valve $50.00
Floor mat - Black $12.00
Fuel Cap $5.00
Fuel Injectors $15 each
Fuel Pressure Regulator $40.00
Igition Control Module $60.00
Ignition Coil - New/Reman $40.00
Left Window Glass $30.00
LH Camshaft $75.00
LH Rocker Intake & Exhaust Rocker Set $90.00
Power Steer Pump $45.00
Radiator $60.00
Rear Carpet $40.00
RH Camshaft $75.00
RH Rocker Intake & Exhaust Rocker Set $90.00
RH Window Reg/Motor $45.00
Right Window Glass $30.00
T Top Left $75.00
T Top Right $75.00
Center Tail Light $30
Tail light Left $30.00
Tail light Right $30.00
PICTURES HERE: http://s1237.photobucket.com/albums/...0Parts%20Sale/
Either PM me or shoot me a text (9 4 9) four six six 4 3 2 1.
Old 08-05-2011 | 12:19 PM
Nissan 300zx Z31 Parts Super Cheap! 84 85 86 87 88 89
Some of these parts are new/Remanufactured, the rest are working and in good condition! Pulled from a 1986 Nissan 300zx base model non-turbo. These are the only parts I have. Please don't ask if I have anything else. Thanks!
AC Compressor $40.00
AC Condenser $20.00
California Compliant Catalytic Converter $50.00
Camshaft Pully / Timing Gears (Set) $15.00
Distributor (with cap & rotor) $50.00
Door handles $10.00
Door Panel Left $30.00
Door Panel Right $30.00
ECU $20.00
Floor mat - Black $10.00
Fuel Cap $5.00
Fuel Injectors $10.00 each
Fuel Pressure Regulator $20.00
Idle Air Control Valve $20.00
Idler Pulley - New/Reman $10.00
Igition Control Module $20.00
Ignition Coil $10.00
Left Window Glass $15.00
LH Camshaft $40.00
LH Rocker Intake & Exhaust Rocker Set $50.00
Power Steer Pump $15.00
Radiator $20.00
Rear Carpet $10.00
RH Camshaft $40.00
RH Rocker Intake & Exhaust Rocker Set $50.00
RH Window Reg/Motor $20.00
Right Window Glass $15.00
Starter - New/Reman $40.00
T Top Left $50.00
T Top Right $50.00
Tail light Center $15.00
PICTURES HERE: http://s1237.photobucket.com/albums/ff4 ... ts%20Sale/
Contact me via email or text me at ( 9 4 9 ) four six six 4 3 2 1.
Old 08-05-2011 | 12:40 PM
For some reason you are never able to find our CLASSIFIEDS...
Merged threads...
silvrhand
05-07-2006 12:07 AM
Skully
04-17-2006 08:25 PM
rob209
07-28-2005 09:01 AM
sticklizard72
03-10-2005 08:35 AM
xtasZ
11-02-2004 09:19 PM
