FS: JWT 700BB turbos, Nismo 740's, JWT ECU, plus more parts
All of these parts have less then 2000 miles on them and are in perfect, like new condition. The turbos are just as they came from JWT, they spin perfectly and have zero shaft play. The plenum has had the casting marks smoothed as you can see in the pictures, but it has not been ported. I can take some more pictures of specific parts if you would like to see them.
JWT 700 BB turbos: $2600
Complete lower plenum setup with the following:
Nismo 740cc injectors
New Nissan factory 95+ fuel rails with all associated parts (new: caps, o-rings, fuel rail to plenum seals, etc.)
Early 94 lower intake plenum modified/machined to fit 95+ fuel rails
95+ fuel injector harness connectors
Total package ready to bolt on: $1050
Dupree 5-bolt split runner downpipes, heat wrapped: $350
JWT ECU programmed for 740's and twin pop (complete ecu ready to plug and play, not just the eprom): $450
AEM wideband O2 sensor/gauge, afr readout, black face with silver bezel: $350
Apexi S-AFC II, limited edition black with white numbers (matches stock gauges): $280
Buy more then one thing and I will cut you a deal. Please email me at brettb122@yahoo.com if you are interested or have any questions. Thanks.
Why are you selling this stuff? Are you selling any suspension components, i.e. sway bars, end links, or strut bars?
I am returning the car to stock to sell it. I tried to sell the car as it sat (modded) but nobody would come up with the money to buy it.
I will most likely be selling the Ground Control adjustable coil-over setup, 300 degree front camber kit, and rear subframe bushing spacers after I get that stuff taken off.
ineedmorepower
FS: 300ZX (90-96)
31
10-22-2008 06:56 PM
