Os giken twin disc clutch & nismo 555 injectors
I have a used Os Giken twin disc clutch part number TS2CD. It is in excellent working condition and has about 3k to 4k of use on it.
Features Chrome-moly flywheel, separator disc, and pressure plate disc. The pressure plate diaphram is steel construction. The discs
are both sprung and full faced featuring a carbon disc material. The kit will include a release bearing and necessary shims for the
release bearing. You will need to buy a stock throw-out bearing as mine is used and pressed in and usually damaged when removed. This
clutch truly has stock smooth engagement with no chatter and holds 600hp plus while remaining firm consistent engagement under heat
and load. I am selling it because I have bought new injectors to run e85 and my power output will soon go beyond the spectrum of this
clutch. The clutch and flywheel combo weighs 33.8lbs.
$700obo
Also I have a set of early style nismo 555cc injectors in the stock fuel rail. These injectors have been balanced and blueprinted by
RC with the necessary paperwork to prove it about 3k-4k ago.I have just ohm tested them and they are all within spec. These injectors
are in perfect running order and have never had e85 runthrough them. Again I have bought new injectors to start to run e85 and these
will not meet my flow capabilities.
$400obo
If you have any questions about either products or want specific pictures don't hesitate to send me an email.
tt1320flyer@hotmail.com
$700obo
$400obo
klouud
350Z Performance / Technical
05-22-2011 09:44 AM
tsefreeflow
FS: 300ZX (90-96)
06-26-2010 06:04 PM
TrumpetRhapsody
12-16-2009 02:04 PM
Mike85t
06-14-2004 12:34 AM
