rough idle
![Talking](https://www.zdriver.com/forums/images/icons/icon10.gif)
Just bought this 1990 its turboless with a cold air kit and exhaust its in really good shape i plan on pulling the motor and tranny and want about 600hp.
and want to do this for under 10g so i guess im looking for advice on motor tranny selection clutch ecu ect.
also the vg30de in this old girl has a rough idle,draw on the alternator from climate control causes the idle to go up around 1500rpm and when i turn the climate control off drops to 700 and bounces around to 800 and back down feels like a miss or like its going to stall but soon as I apply the gas she runs like a dream smoothly then if you try to maintain a certain speed the car starts to do weird **** go away when you accelerate or take your foot off
then I started to smell pure fuel!??????
heres what i think But im no nissan mechanic
I think maybe the fuel rail is leaking! but i see no leakyleaky
I think that might be the constant speed jerkyness problem
I just want to fix this problem before i sell this motor to help out with the new one! I heard these are common issues just looking for advice before paying someone for it.
I
I
![ryencoke is offline](https://www.zdriver.com/forums/images/statusicon/user_offline.gif)
Check codes
You should run codes on ECU or possibly your MAF sensor is acting up my car had simmilar problems and I found out the MAF was working improperly (new MAF fixed all problems) but I didn't find out until after I changed the fuel pump (wasted $$). All my problems started just like yours then boom can't even drive. Idle'd fine but stalls as soon as I accellerate I have a 90' N/T.
![Angelz300zx is offline](https://www.zdriver.com/forums/images/statusicon/user_offline.gif)
