BARTCO CNC Services
#27
i will be making alot of stuff very soon and as i do i will post it up for you too see and can give references from those who have bought stuff.. right now im just making lists of stuff people want so i can see what i should make first and such
#29
well have a update on the camber plates(these are for the z31)..was able to finish up the sliders... this isnt the final product you will see 2 oppesss... we where adjusting our chamfers and the machine decided to be weird... my camera died after i took these so i will get some finished pics up soon....
u guys have mentioned that some of the s30 s130 only have weld in types...if this is the case id be willing to make some as bolt in... im selling these to the z31 guys for $150pr so let me know if you guys would be interested i designed these to be used with the stock spring and perch as well as with coilovers so i can do the same for the s30 and s130
#31
what kind of price ranges are the s130 ones for and what years exactly does the s30 cover so i can source a complete front corner to make them from
#32
heres the finished unit minus anodizing as that will be done after these are test fitted,, and i wont get the rest of my chemicals until the end of this coming week. these fit the z31's... i should have a set of stock 240z front hats so i can make bolt in units for you guys soon
#38
heres something i was able to machine out today.. this is for the s12 but it will also work for a z31 with the bolt on rotor... this hat will bolt up to either a 11.75 or 12.2 rotors that i am using in kits for the s12... now if you guys are interested i can also make these kit for the z31 both bolt on and slip on rotor styles
heres the caliper adapter plates i just finished up for the s12...
#40
that would be a bit tricky right now as we dont have the 4th axis yet but once that happens this kind of stuff will be easy
#41
#43
You should machine up a set of front spindles, thats lets you use replaceable shocks, not cartridges while still letting you use the stock balljoints and tierods for the S130.
I have a set I can donate So long as I get to have a set when their done
#44
well heres some big brake kits for you z31 guys these are for the bolt on style hubs.. the rotors are 12.2" x .81 they will be avaiable in either drilled or solid... there will be 2 iron calipers options both pictured... z32 4pot and also a wilwood 4 or 6pot as well... i will work on prices and slip on style hubs once i get my hands on them
this 4 pot has a 1.5" and 1.12" pistons
these are the larger iron 4 pots with 1.5" pistons all around
#49
#50
