lug nuts
Old 10-25-2007 | 12:32 PM
tonsoffun300zx's Avatar
West Coast!
lug nuts
hey has anybody ever broke a lugnut with a hammer if so how hard was it?
Old 10-25-2007 | 12:45 PM
Buahahaha! I've been there. I once tried to remove a stupid Ford locking lugnut on an Escort/Tracer by welding a lugnut ontop of it... snapped it right down at the rim base. Sorry to say, it cost me about $40 in carbide drill bits, $20 for a junk yard rim, and about 3 hours of drilling/chiseling to get it off.
Now... before doing all that, take it to a tire shop & see if they can help you.
And I assume you are asking how hard it was TO FIX?
Old 10-25-2007 | 01:08 PM
West Coast!
no i want to break the lug nut
Old 10-25-2007 | 01:10 PM
Uh... don't use a hammer.... you'll kill the rim long before breaking the lugnut. Tap a socket over the top & use a ratchet to remove it.
entropy31's Avatar
The Cake Is A Lie!
break it loose??? i don't get it...
Old 10-25-2007 | 02:06 PM
260zturbo's Avatar
Stupid Hurricanes...
if u if u want to break it in half go get a torch or hack saw...if u want to break it loose go get some sockets that u use to get rounded bolts off.....really dont understand what u are asking.
Old 10-25-2007 | 03:01 PM
West Coast!
ok there is this lug nut that i can't get off my car because it needs a special key and i don't have the key to it but i need to get it off so im thinking about breaking the lug nut
Old 10-25-2007 | 03:04 PM
Dooo it......
Old 10-25-2007 | 03:10 PM
West Coast!
how can i do that? like force it over then take it off like normal?
Old 10-25-2007 | 03:11 PM
thxone's Avatar
You and I are in the same boat...stupid lock nuts. Are your "nuts" recessed or flush with the rim? This is what I have to figure out how to remove...
If your "nuts" are sticking out above the hole then yes, hammer a socket onto it and use a long handled breaker bar or ratchet to take it off as normal...no need to break the stud off...however if it looks like mine...flush with the hole you are going to have problems.
Old 10-25-2007 | 03:13 PM
West Coast!
mine sticks out and is it hard to force it over the lug nut?
Old 10-25-2007 | 03:20 PM
You'll need to tap it on w/ a hammer... and kiss that socket goodbye (you'll never get the lugnut out of the socket). $2 is a cheap price to pay. Thxone... You should be able to get a socket in there. I had the same amount of room as that. I think I used a sparkplug socket.
Old 10-25-2007 | 03:21 PM
West Coast!
thanks hopefully i'll get it off today
Old 10-25-2007 | 03:33 PM
thxone's Avatar
You would think so....let me guess, 13/16th socket?
Old 10-25-2007 | 03:34 PM
260zturbo's Avatar
go to homedepot or autozone. get the sockets that are used to get off rounded bolts... it will get those off at ease.
http://www.sears.com/shc/s/p_10153_1...unded+off+bolt
Old 10-25-2007 | 03:37 PM
West Coast!
im broke as a joke and i only need to take them off this once after that i'll switch to regular kind
Old 10-25-2007 | 03:39 PM
thxone's Avatar
Sorry 260ZTurbo...I am broke as a joke...gonna try a 2lb sledge and a 23mm socket...brb
Old 10-25-2007 | 03:43 PM
West Coast!
yes it is a 13/16 what size should i buy to fit over it?
Old 10-25-2007 | 04:16 PM
thxone's Avatar
Well I just got my back two lock nuts off WOOHOO!!!! I used a 23mm socket, 2lb sledge and an old tq wrench.
I would say use a socket that is JUST BARELY smaller than the lock nut and hammer that thing on there good and tight then just remove the lock nut as you would a normal lug nut BUT DO IT SLOW, DON"T JERK IT, slow and even pulling. Whatever size works make sure you have two or three of that same size in case you break one...my socket split as I was hammering it on the second lock nut so have a backup and a backup for your backup...good luck man...you have it easier trust me. Can you take a pic of the lock nut?
Old 10-25-2007 | 04:20 PM
Well look at that!
Old 10-25-2007 | 05:08 PM
West Coast!
not really
Old 10-25-2007 | 06:42 PM
not really
uh... not really what?
Old 10-25-2007 | 06:46 PM
West Coast!
i can't really take a pic of the lug nut i don't have a camera
Old 10-25-2007 | 06:53 PM
entropy31's Avatar
The Cake Is A Lie!
that was pretty random....
Old 10-25-2007 | 09:30 PM
Spraguepsycho1's Avatar
The best way I've ever seen to remove those style locks without the key is to use a rotohammer style drill with a wide chisel bit. Just center it on the lug, set the drill to rotate in the counter clockwise direction and hammer away. Without a rotohammer you might be able to remove it just using a good chisel and a hammer digging it into the outside edge and driving it off slowly. It really shouldn't be too tight since usually that style key slips out before you can get them too tight.
Quick Reply: lug nuts
