93 Nissan Pickup
Old 01-12-2010 | 03:30 PM
BlueKitsune's Avatar
Intrawebz Wizard
93 Nissan Pickup
I'm working on this awesome truck for a family member (might trade them for my Chevy) but atm theres 2 glaring issues
The Blower for the heater isnt working at all. I check the wires and Its got + but the - of the connector isnt grounded so the fan work work. Any ideas?
2nd is the fact the rear brakes lock up MUCH faster then the front when having to stop fast (I nearly flipped the truck today not knowing this when someone pulled into my lane...)
So ya Just wondering if anyone has any ideas to fix these? Thanks!
Old 01-12-2010 | 04:21 PM
Have you tried connecting the ground?
Start w/ bleeding the system (all 4 corners + master).
Old 01-12-2010 | 05:26 PM
Intrawebz Wizard
I mean the plug that goes into the blower motor has no ground, when I test it against the trucks ground is reads infinity on ohms.
Old 01-13-2010 | 02:56 AM
Niku-Sama's Avatar
eff good grammar
well if its got infinity ground, theres a short in the wiring, the fuse is blown.
if the fuse is good and thats the only problem i say clip it and ground it to the body some place, ground is ground
how do you flip a truck when the rears are locking before the fronts?
Old 01-13-2010 | 12:35 PM
Intrawebz Wizard
Thats what I was thinking of doing.
And you almost flip a truck when the rears lock and the truck fishtails almost sideways at 45mph
Old 01-13-2010 | 02:59 PM
Niku-Sama's Avatar
eff good grammar
if the a proportioning valve for the brakes in these trucks?
Old 01-13-2010 | 05:52 PM
Intrawebz Wizard
I have no idea
side note I found the problem with the blower, its the switch itself! Luckily Checker can get it. For $150...
Old 01-14-2010 | 01:28 AM
Niku-Sama's Avatar
eff good grammar
93hmm...i bet that switch has been used since the mid 80's in other cars but another thing to check, make sure theres not a hidden fuse for the blower motor, some times its on the motor or somewhere in the harness for it.
when they go they can cause the motor to not run in any of the middle speeds, just the lowest and highest
Old 01-14-2010 | 11:00 AM
Intrawebz Wizard
Well Idk what I did but the fan seems to work now. its a 4 speed switch and 1 and 2 works but only between 3 and 4 does it work...
mastin39180
07-10-2014 08:45 PM
davidjoe007
03-13-2013 04:32 PM
EatmyDust
06-25-2006 04:30 PM
CanyonCarver
Other Cars
10-27-2004 06:02 AM
BASEBALL248
11-20-2003 01:18 AM
Quick Reply: 93 Nissan Pickup
