Damn freaking metro!!!
I've been in denial for the last month about my Geo Metro having a blown head gasket. One day it got really hot on the freeway (100+ outside, a/c full blast). I pulled over well before it maxed out & let it cool down. It had puked out coolant from the over flow so I added some water & limped home. Since then, every time I drive it on the freeway, it will puke all it's coolant out the overflow. I did a compression test, all 3 are fine. Spark plugs look fine. Flushed radiator, flows fine, fins fine. No white exhaust smoke, no chugging, just bubbles in the coolant. I have even flushed the cooling system & changed the coolant twice. With new coolant it's much more stable, but as soon as the thermostat opens, the coolant bubbles in the radiator & finally boils over. All I can think of is that there's a pinhole in the head gasket which is pushing compressed air from a cylinder into a coolant passage.
On the bright side, while I'll be wrenching away on it in the garage, I will be jamming to internet tunes on my new garage computer. I just need to build a wifi antenna....
Have you tried replacing the radiator cap? Our jimmy would constantly just boil over the coolant whenever we drove it on a hot day... but it wouldn't over heat. We replaced the coolant cap and walla! I guess it wasn't holding the pressure which helps raise the boiling temperature.
Low oil maybe? That seems to be a common culprit for overheating with these miracles of engineering. Why not see what the pros think . . .
http://geometroforum.com/site/
That is retarded. Plain and simple. I would have called the cops on you if I saw you doing that crap near my neighborhood.
its not like its difficult to work on, quit yer bitchin and pull that motor.
just out of curisoity could you weigh the motor? i always wondered how much a 3 cyl weighed in one of those, i dont think its light, i hear they have cylinder walls like the great wall of china
yeah dude!! yesterday i saw a seven year old an i arm wrestled him but after i won i just beat the **** out of him for fun!!
ever been stuck with a really obnoxious 8yr old? but you think you cant hit him cuz hes 8.
just lay that little **** out with a right hook.
its the same level of satisfaction as beating a metro in a race
but its all cool, your not a ***** for beating up kids, he started it
3cyl FTW!
