Temp gauge suddenly not working
Old 06-27-2005, 12:49 PM
davidjoe007's Avatar
Hi Everyone,
I was working in the motor compartment changing some old fuel lines and then adjusting the timing...everything going smooth... The car is warm by now... I took a look at the gauges and the temperature gauge had no reading. I think a loose wire in the motor compartment but couldn't find any loose wires. Any suggestions.
davidjoe007 is offline
Old 06-27-2005, 02:26 PM
Check your fuses, if that is good, check your temp sensor, and also the plug that goes into the front of the engine. I found out before when I was running my Z, and the temp was not working. I looked under the hood, and found a loose plug in front of the engine. Jiggled it around a bit, and the temp gauge worked again. Just had to secure it with another clip that goes around the plug itself. Hope this helps you out! And again glad to hear you got another Z, good luck to you!
WildmaN is offline
Old 06-28-2005, 11:17 AM
thanks
Thanks... the coolant temperature sensor right above the thermostate housing was loose.
Thanks again... it great to be driving a Z again. 83 t-tops baby.
Old 06-28-2005, 01:43 PM
Right on man glad I could help you out. Anyway that is a sweet Z bro'! Take care of it, and get a good decent alarm on it.
WildmaN is offline
Old 03-07-2023, 09:28 AM
Z you later's Avatar
Dave,
Where in the Bay do you live?
I'm in San Mateo.
280Zx Turbo 5 speed.....appreciate my Z and others.
Z you later is offline
BADASSTT
06-21-2009 10:23 AM
82zxturbo
10-30-2007 09:28 PM
pmr2000
03-14-2006 09:49 AM
Heat Rave R
04-15-2005 04:58 PM
RED-Z-1
08-14-2003 11:46 PM
Quick Reply: Temp gauge suddenly not working
