Holy insane offsets Batman...
Old 08-27-2006 | 12:00 PM
roneski's Avatar
I may have gone too far...
Old 08-27-2006 | 12:45 PM
Nforce1's Avatar
If that was my car.... One word would come to mind.... CURBED :-( lol
Old 08-27-2006 | 01:07 PM
rob209's Avatar
what's the offset, about -15??? it is certainly beyond flush with the fender...
Old 08-27-2006 | 02:39 PM
i8acobra's Avatar
I would definitely send them back and get the correct offset. In addition to just not looking right. That's just asking for damage.
Old 08-27-2006 | 09:21 PM
roneski's Avatar
I've gotten good responses from guys at driver and my350Z running the same offsets. The clearance is exaggerated because the car is in the air and the camber is probably sitting positive compared to mormal. Once it's back on the ground it should look more normal and the camber should fall back negative. I may have to raise the car back up a quarter of an inch or so, but I was going to do that anyways. We'll see how it goes.
http://www.my350z.com/forum/showthread.php?t=213249
http://g35driver.com/forums/showthread.php?t=114029
Old 08-27-2006 | 11:40 PM
pope's Avatar
go for it. i think it will look perfect. you might have to setup some camber but with your coilovers it wont be a problem at all. everyone else is right about it sitting in the air like that.... once it sits on the ground with some tires mounted, its going to look perfect. you will have the best wheel/tire setup in vegas as far as im concerned.
Old 08-28-2006 | 01:32 AM
702Fairlady's Avatar
sorry to go off topic, but when can I come snag those bottles from ya
Old 08-28-2006 | 08:31 AM
Love2ridepow's Avatar
I think it will look perfect once you set her down. Just make sure you put some DR's on the back!
Old 08-28-2006 | 08:40 AM
rob209's Avatar
what size are they? offset? i'm sure you know, but once tires have been mounted you can't return them.
anyone interested in a set of 18" drag radials?
Old 08-28-2006 | 08:57 AM
i8acobra's Avatar
Remember, unless you plan on going for the "streched" look, the tires are going to stick out 1/4 - 1/2" more than the rims.
Old 08-28-2006 | 10:38 AM
roneski's Avatar
Well I'm going to run pretty much the same tire sizes that I ran on the Mayas. A 275 on the rear 10.5 which should be pretty close to even and a 245 on the front 9.5 wich might be a little on the stretch side.
Old 08-28-2006 | 10:41 AM
roneski's Avatar
Which reminds me that I have a used set of Toyo T1S 275/35r19 and 245/35r19 sitting around if anyone wants them. They are in decent condition and they're free.
They'd make a nice backup set for anyone still running T1Ss since you can't get replacements anymore.
Old 08-28-2006 | 10:50 AM
pope's Avatar
i am running 275's on my rears (10.5) and its a bit of a stretched look so you can count on it being stretched a little in the back too
Old 08-28-2006 | 10:55 AM
Smittyz33's Avatar
I need tires...how much tread left? Are they weather cracking yet?...dibs.
Old 08-28-2006 | 12:03 PM
roneski's Avatar
No cracking, just some uneven wear because of all the negative camber that I was running. You're welcome to check them out.
Old 08-28-2006 | 12:30 PM
SinCity350Z's Avatar
Las Vegas Moderator
I've got dibs behind Smitty if he doesn't want them!
Old 08-28-2006 | 06:33 PM
Smittyz33's Avatar
I'll check them out sometime this week...
Old 08-29-2006 | 10:54 AM
clearsector's Avatar
im sitting on 275x19 10.5 -18 / 245x19 9.5 -17 volks..
only rubs on the rear when i hit big dips on the freeway or hit a dip taking an aggressive turn.. (sitting about 1.5 finger space on the rear)
nothing a fender roll wont fix.. im thinking of renting the roller from www.rollyourfender.com
let me know if you want to partake and split the $50 fee.. ill cover the $300 deposit
Old 08-29-2006 | 11:23 AM
roneski's Avatar
Yogi said that someone in town has a rolling tool. I'll let you know if I can get a hold of it.
Old 08-29-2006 | 02:11 PM
rob209's Avatar
throw up some pix once you get them mounted, Ty!!!!
Old 08-29-2006 | 09:45 PM
vegas_speedster's Avatar
I didnt think my wheels would fit either until I actually set the car on the ground.
Old 09-01-2006 | 11:12 AM
Gee3Five's Avatar
Hey Ty,
Where are the pics??
Old 09-01-2006 | 08:33 PM
Smittyz33's Avatar
Apex says it best...
Originally Posted by Late Apex
Old 09-17-2006 | 08:19 PM
Smittyz33's Avatar
Mike, Ty's Toyos are all yours as I have bought a set of BFG G-force KDW NTs.
Old 09-18-2006 | 12:50 PM
roneski's Avatar
Tires are still available.
wingsuit
05-20-2013 01:34 PM
Dawei
15
05-15-2012 06:58 PM
900rrguy
10-30-2004 01:04 PM
robertpark
05-21-2003 05:23 PM
980MAK
09-21-2001 03:39 PM
Quick Reply: Holy insane offsets Batman...
