Need a car with VDC (350Z or G35) for testing
I need a local 350Z Track or GT or a G35 to test a new electronic device that reverses the TCS/VDC switch. This basically sets the TCS/VDC to default off instead of on. I already tested it on my car and need a car with VDC to test it on. You will receive a device for free as payment.
Thanks.
Thanks.
Originally Posted by roneski
You can use mine as long as you don't blow up anything real important.
Originally Posted by HDPD350Z
How much will this device retail for? I might be interested in buying one. Mine has TCS.
You can go ahead and use Kam or Dennis if either are available before I am. I don't mind.
I should be free after 3:30p today, but there's the Jason's Deli thing at 7:30p. How long do you think that install would take?
I already have one installed in my car. It's mounted in front of the center console in a blank plate. I can either set it to always be off or I can set it the other way for normal operation. Quite handy when out at the track so you don't forget that you left it on halfway through a run.
hey kam, long time no see.
Originally Posted by i8acobra
Who made yours?
The only thing I don't like about it (and it may be hooked up wrong) is that when I use the aftermarket switch to disable VDC I can't turn it back on unless I shut the car off.
